portupgrade
portupgrade
Сообщение Mechanic » 15 мар 2010, 21:37
на свеже поставленной системе решил провести апдейт портов, для этих целей решил воспользоваться программой portupgrade.
Но при ее установке получаю ошибку:
===>  Applying FreeBSD patches for help2man-1.37.1_2
===>   help2man-1.37.1_2 depends on file: /usr/local/lib/perl5/site_perl/5.8.9/mach/Locale/gettext.pm - not found
===>    Verifying install for /usr/local/lib/perl5/site_perl/5.8.9/mach/Locale/gettext.pm in /usr/ports/devel/p5-Locale-gettext
===>  Vulnerability check disabled, database not found
===>  Extracting for p5-gettext-1.05_2
=> MD5 Checksum OK for gettext-1.05.tar.gz.
=> SHA256 Checksum OK for gettext-1.05.tar.gz.
===>   p5-gettext-1.05_2 depends on file: /usr/local/bin/perl5.8.9 - found
===>  Patching for p5-gettext-1.05_2
===>  Applying FreeBSD patches for p5-gettext-1.05_2
===>   p5-gettext-1.05_2 depends on shared library: intl - found
===>  Configuring for p5-gettext-1.05_2
checking for gettext... no
checking for gettext in -L/usr/local/lib -lintl -I/usr/local/include... yes
checking for dgettext in -L/usr/local/lib -lintl -I/usr/local/include... yes
checking for ngettext in -L/usr/local/lib -lintl -I/usr/local/include... yes
checking for bind_textdomain_codeset in -L/usr/local/lib -lintl -I/usr/local/include... yes
Writing Makefile for Locale::gettext
===>  Building for p5-gettext-1.05_2
make: don't know how to make all. Stop
*** Error code 1
Stop in /usr/ports/devel/p5-Locale-gettext.
*** Error code 1
Stop in /usr/ports/misc/help2man.
*** Error code 1
Stop in /usr/ports/devel/autoconf262.
*** Error code 1
Stop in /usr/ports/devel/automake110.
*** Error code 1
Stop in /usr/ports/lang/ruby18.
*** Error code 1
*** Error code 1
Stop in /usr/ports/ports-mgmt/portupgrade.
*** Error code 1
в чем может быть причина ?
Mechanic
Re: portupgrade
Сообщение mr_A3ap41k » 15 мар 2010, 22:29
mr_A3ap41k
Re: portupgrade
Сообщение Mechanic » 15 мар 2010, 23:58
обновил дерево портов через porsnap , но ошибка не изменилась
удалил дерево и заново собрал, тожесаоме
Mechanic
Re: portupgrade
Сообщение lehisnoe » 16 мар 2010, 09:20
Попробуй поставить уже собранный пакет, из-за которого проблемы:
pkg_add -r p5-gettext
или даже
pkg_add -r help2man
Все равно потом тебя ждет portupgrade -a :)
Re: portupgrade
Сообщение root » 16 мар 2010, 14:10
а если зайти в порт
и там руками дать
make install clean
будет более понятней, на чем именно он там валится
Re: portupgrade
Сообщение Mechanic » 17 мар 2010, 21:20
он валится именно на этом сообщении :(
у меня такое было пол года назад на другом сервере, но потом путем обновления чего-то ошибка исчезла, попробую еще через pkg_add
Mechanic
Re: portupgrade
Сообщение root » 18 мар 2010, 10:20
Mechanic писал(а):он валится именно на этом сообщении
а если начать просто с
make
тоже ?
очень странно, все же сделай
portsnap fetch update
ещё раз
так же м.б. сначала обновить все зависимости:
Information for p5-gettext-1.05_2:
Depends on:
Dependency: perl-5.8.9_3
Dependency: libiconv-1.13.1_1
Dependency: gettext-0.17_1
а потом уже пробовать собрать его снова
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 42
