Помогите новичку пожалуйста.
Как при такой конфигурации:
- Код: Выделить всё
 version 15.1
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
no service dhcp
hostname CISCO-881
boot-start-marker
boot-end-marker
logging buffered 100000
logging monitor errors
no aaa new-model
memory-size iomem 10
no ip source-route
ip vrf extnet
ip cef
no ip bootp server
no ip domain lookup
ip domain name xxxxxx.ru
ip name-server 192.168.200.1
ip name-server 192.168.200.11
no ipv6 cef
multilink bundle-name authenticated
crypto pki token default removal timeout 0
crypto pki trustpoint TP-self-signed-458237257
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-458237257
revocation-check none
crypto pki certificate chain TP-self-signed-458237257
certificate self-signed 01 nvram:IOS-Self-Sig#4.cer
license udi pid CISCO881-SEC-K9 sn FCZ151492SD
no spanning-tree vlan 1
no spanning-tree vlan 2
username root privilege 15 secret 5
interface Loopback1
ip vrf forwarding extnet
ip address 10.0.0.250 255.255.255.255
interface Tunnel1
description extnet
bandwidth 10000
ip address 192.168.20.2 255.255.255.252
ip mtu 1400
tunnel source FastEthernet4
tunnel destination xxx.xx.x.xxx
interface FastEthernet0
interface FastEthernet1
switchport access vlan 2
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$
ip address yy.yyy.yyy.yy 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 192.168.200.230 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1452
interface Vlan2
description extnet2
ip address 192.168.23.111 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip local pool extnet 10.0.0.1 10.0.0.250 group extnet
no ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map provider interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 yy.yyy.yyy.y
ip route 172.20.200.21 255.255.255.255 Vlan2
ip route 172.20.200.25 255.255.255.255 Vlan2
ip route vrf extnet 0.0.0.0 0.0.0.0 Tunnel1
ip access-list extended LAN_IN
permit ip any any
logging esm config
logging trap debugging
logging 192.168.200.100
access-list 23 permit 192.168.200.100
access-list 23 permit 192.168.200.65
no cdp run
route-map provider permit 10
match ip address nat-traffic LAN_IN
match interface FastEthernet4
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
end
Что бы была доступна сеть extnet2 из сети extnet? И было бы совсем замечательно если бы еще и локальную сеть видела та что на Vlan1.
Все что смог сделать, это на Vlan2 так же сделать NAT но все равно сеть exnet не видит exnet2 =(
