zaikini писал(а):Все объекты inetnum сделать со статусом ASSIGNED PA.
если RIPE уже ассайнул ему весь его блок он так сможет сделать
для удобства использования WebUpdates, дабы не вводить пароль от объекта mntner, можно использовать авторизацию до проведения необходимых изменений: смотреть
Selecting [Authorization] from the menu, you can enter a clear text
password that can be used on all of your updates during the time you
specified. You can enter the password to be used, and for how long it will
be remembered by the application. Clicking Register, the password you
entered will be stored on your computer as an encrypted cookie. The same
screen will be displayed after clicking Register.
My update failed. Please explain why it failed.
There are many reasons why an update could fail. Usually, the update message stating the failure is self-explanatory. The errors and warnings are contained in the "ERROR:" and "WARNING:" lines appended to the object which could not be updated. Please read these lines carefully. Often the errors are simple syntax errors in the object: check your object for typos.
Sometimes, your update fails with this error message: "authorisation failed, request forwarded to maintainer". This means that you haven't supplied the correct authentication for the maintainer that protects the object. The attempted update is sent to the maintainer, to notify him that someone tried to change his object.
kote писал(а):not authenticated by: MNT-XXXXX
