При создании объекта domain в базе ripe получаю такую ошибку:
glue nameserver ns1.xxxx.ru must be within the domain that is being delegated.
Подскажите куда смотреть.
domain: 32.150.217.in-addr.arpa
descr: Reverse delegation for TRANS-TELECOM-NET
remarks: INFRA AW
admin-c: KTTK-RIPE
tech-c: KTTK-RIPE
zone-c: KTTK-RIPE
nserver: dns-prim.transtk.ru
nserver: dns-sec.transtk.ru
nserver: ns.transtelecom.net
nserver: ns1.transtelecom.net
mnt-by: TRANSTELECOM-MNTlonglike писал(а):Спасибо!
nserver: rel.vrangel.ru 62.33.172.5
nserver: dns1.vrangel.ru 94.229.247.1
domainer писал(а):и так:
domain: 240-247.229.94.in-addr.arpa
Step 2: Preparing the Reverse Delegation
Because of how DNS works, you will need to chop your address block into "chunks" that can be delegated.
For an IPv4 address block, you will have to create one or multiple /24 or /16 type address blocks mapped into in-addr.arpa domains
For IPv6, you will have to map a /32 address block into the ip6.arpa domain
vrangel.ru. 3319 IN NS rel.vrangel.ru.
vrangel.ru. 3319 IN NS dns1.vrangel.ru.
vrangel.ru. 3319 IN NS ns4.nic.ru.
vrangel.ru. 3319 IN NS ns8.nic.ru.NS Servers
Make sure that you have at least two name servers that are authoritative for the zone. The resolvable names of these NS servers should be in the NS resource records of the zone. The name servers should be on different subnets.
nslookup 94.229.247.1 62.33.172.5Server: 62.33.172.5
Address: 62.33.172.5#53
1.247.229.94.in-addr.arpa name = dns1.vrangel.ru.
domainer писал(а):Отсылаю следующее:
***RDNS: (related to set) INFO: Several tests were skipped for one or more servers having the version of the zone with serial number 2010052023, which had already been checked.
