MPD5 + FreeBSD7.1
MPD5 + FreeBSD7.1
Сообщение iyeadm » 16 мар 2009, 13:21
Приветствую!
Имеется система:
7.1-RELEASE FreeBSD 7.1-RELEASE #0
Поставлен пакет из портов:
mpd-5.1_1           Multi-link PPP daemon based on netgraph(4)
Конфиг мпд:
pppoe_server:
        create bundle template B
        set ipcp ranges xx.xx.xx.xx/32 0.0.0.0/0
        set bundle enable compression
        set iface idle 0
        set iface disable proxy-arp
        set iface enable tcpmssfix
        set ipcp yes vjcomp
        set ipcp dns yy.yy.yy.yy
        set ccp yes mppc
        set mppc yes e40
        set mppc yes e56
        set mppc yes e128
        set mppc yes stateless
        create link template PPPoE pppoe
        set link enable multilink
        set link action bundle B
        set link yes acfcomp protocomp
        set link disable chap pap eap
        set link enable chap
        set link keep-alive 10 60
        set link bandwidth 128000
        set link mtu 1472
        set link mru 1472
        load radius
        set pppoe service "*"
        set link max-children 300
        set pppoe iface ale0
        set link enable incoming
Все работает и поднимается но почему то в интерфейсах вижу:
ng7: flags=88d1<UP,POINTOPOINT,RUNNING,NOARP,SIMPLEX,MULTICAST> metric 0 mtu 576
        inet xx.xx.xx.xx --> xy.xy.xy.xy netmask 0xffffffff
Хотя судя по логам сервер мту отдает:
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: SendConfigReq #1
Mar 16 14:02:25 inet mpd: [PPPoE-9]   PROTOCOMP
Mar 16 14:02:25 inet mpd: [PPPoE-9]   MRU 1472
Mar 16 14:02:25 inet mpd: [PPPoE-9]   MAGICNUM 4c05c041
Mar 16 14:02:25 inet mpd: [PPPoE-9]   AUTHPROTO CHAP MSOFTv2
Mar 16 14:02:25 inet mpd: [PPPoE-9]   MP MRRU 2048
Mar 16 14:02:25 inet mpd: [PPPoE-9]   MP SHORTSEQ
Mar 16 14:02:25 inet mpd: [PPPoE-9]   ENDPOINTDISC [802.1] 00 1f c6 c5 65 9f
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: rec'd Configure Request #0 (Req-Sent)
Mar 16 14:02:25 inet mpd: [PPPoE-9]   MRU 1480
Mar 16 14:02:25 inet mpd: [PPPoE-9]   MAGICNUM 7fc630d5
Mar 16 14:02:25 inet mpd: [PPPoE-9]   CALLBACK 6
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: SendConfigRej #0
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: rec'd Configure Reject #1 (Req-Sent)
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: SendConfigReq #2
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: rec'd Configure Request #1 (Req-Sent)
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: SendConfigAck #1
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: state change Req-Sent --> Ack-Sent
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: rec'd Configure Ack #2 (Ack-Sent)
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: state change Ack-Sent --> Opened
Mar 16 14:02:25 inet mpd: [PPPoE-9] LCP: auth: peer wants nothing, I want CHAP
Подскажите куда копать ? Заранее благодарен за ответы.
iyeadm
Re: MPD5 + FreeBSD7.1
Сообщение lehisnoe » 16 мар 2009, 13:56
На 99% - у клиента в конфиге выставлено MRU=576
Сообщение iyeadm » 16 мар 2009, 13:58
Нет ) . Тому подтверждение - лог. Юзер хочет мту 1480.
iyeadm
Сообщение root » 16 мар 2009, 14:03
как юзер подключается к серверу ? точнее через что ? Ethernet ? DSL ? и т.п.
какие навтройки у клиента ? какая у него ОСь ?
Сообщение lehisnoe » 16 мар 2009, 14:04
iyeadm писал(а):Нет ) . Тому подтверждение - лог. Юзер хочет мту 1480.
Да, согласен, проглядел :(
Сообщение iyeadm » 16 мар 2009, 14:13
Эзернет. Ось Вин Хр. Настройки все стандартны - вбивал тока логин и пароль. Но ось все равно какая - со всех осей одинакого.
iyeadm
Сообщение root » 16 мар 2009, 14:45
покажи вывод ifconfig сетевухи, которая смотрит в сторону юзеров
Сообщение iyeadm » 16 мар 2009, 14:48
ale0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=319b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,WOL_MCAST,WOL_MAGIC>
        ether 00:1f:c6:c5:65:9f
        inet xx.xx.xx.xx netmask 0xffffffc0 broadcast xx.xx.xx.xy
        status: active
iyeadm
Сообщение root » 16 мар 2009, 16:57
1. а если поставить:
 set link mtu 1460
 set link mru 1460
или даже 1396
2. убрать
3. добавить:
set iface disable on-demand
set ipcp no vjcomp
Сообщение iyeadm » 16 мар 2009, 20:19
Пробовал ставить разные значения мту - ему вообще фиолетово что в конфиге написано. Ширину полосы убирал - ноль реакции. Обновился и поставил пересобираться ядро - завтра будем посмотреть.
iyeadm
