natd RDP
natd RDP
Сообщение dimondack » 10 июл 2018, 21:06
Всем привет
Захотел RDP организовать
по такой схеме
действовал по мотивам http://subnets.ru/blog/?p=1605
имеется вот такой конфиг
dos@vis:/etc# cat rc.conf
hostname="vis"
ifconfig_em0="inet x.x.x.158 netmask 255.255.255.240"
defaultrouter="x.x.x.145"
ifconfig_em1="inet 192.168.50.99 netmask 255.255.255.0"
route_local="-net 192.168.50.0/24 -interface em1"
sshd_enable="YES"
# Set dumpdev to "AUTO" to enable crash dumps, "NO" to disable
dumpdev="AUTO"
#firewall
firewall_enable="YES"
firewall_script="/etc/ipfw.rules"
firewall_logging="YES"
gateway_enable="YES"
#natd
natd_enable="YES"
natd_interface="em0"
natd_flags="-dynamic -m"
#natd_flags="-f /etc/natd.conf"
#natd_flags="-redirect_port udp 192.168.50.20:3389 3389 -redirect_port udp 192.168.50.20:4899 4899"
dos@vis:/etc# netstat -rn
Routing tables
Internet:
Destination        Gateway            Flags     Netif Expire
default            x.x.x.145     UGS         em0
x.x.x.144/28  link#1             U           em0
x.x.x.158     link#1             UHS         lo0
127.0.0.1          link#3             UH          lo0
192.168.50.0/24    link#2             U           em1
192.168.50.99      link#2             UHS         lo0
dos@vis:~/kernels# kldstat -v -q
                473 x86bios
 2    2 0xffffffff82421000 20198    ipfw.ko (/boot/kernel/ipfw.ko)
        Contains modules:
                Id Name
                501 ipfw
 3    1 0xffffffff82442000 13f0     ipdivert.ko (/boot/kernel/ipdivert.ko)
        Contains modules:
                Id Name
                502 ipdivert
dos@vis:/home/deos/forward_port# ipfw -t list
00001 Tue Jul 10 19:59:42 2018 allow ip from any to any via em1
00015 Tue Jul 10 19:59:36 2018 allow ip from any to any via lo0
00018 Tue Jul 10 19:59:19 2018 divert 8668 ip from any to any in via em0
00019                         check-state :default
00022                         skipto 800 tcp from any to 8.8.8.8 53 out via em0 setup keep-state :default
00023 Tue Jul 10 19:58:19 2018 skipto 800 udp from any to 8.8.8.8 53 out via em0 keep-state :default
00110                         skipto 800 tcp from any to any 22 out via em0 setup keep-state :default
00415                         allow tcp from t.t.t.0/24 to any 22 in via em0 setup limit src-addr 5 :default
00421                         deny tcp from any to any 22 in via em0
00700 Tue Jul 10 19:59:19 2018 deny log ip from any to any in via em0
00750                         deny log ip from any to any out via em0
00800 Tue Jul 10 19:58:54 2018 divert 8668 ip from any to any out via em0
00801 Tue Jul 10 19:58:54 2018 allow ip from any to any
65535                         deny ip from any to any
dos@vis:/home/deos/forward_port# cat 1
111nat.sh* 1natd_.sh*
dos@vis:/home/deos/forward_port# cat 111nat.sh
#!/bin/sh
natd -p 8670 -s -m -a x.x.x.158 -redirect_port tcp 192.168.50.20:3389 3389
ipfw add 2 divert 8670 tcp from any to x.x.x.158 3389
ipfw add 3 divert 8670 tcp from 192.168.50.20 3389 to any
natd -s -m -a 192.168.50.99 -p 8671
ipfw add 12 divert 8671 tcp from any to 192.168.50.99 dst-port 3389
ipfw add 13 divert 8671 tcp from 192.168.50.20 3389 to 192.168.50.99
dos@vis:/home/deos/forward_port# dos@vis:/home/deos/forward_port#
dos@vis:/home/deos/forward_port# ./111nat.sh
00002 divert 8670 tcp from any to x.x.x.158 3389
00003 divert 8670 tcp from 192.168.50.20 3389 to any
00012 divert 8671 tcp from any to 192.168.50.99 3389
00013 divert 8671 tcp from 192.168.50.20 3389 to 192.168.50.99
00001 Tue Jul 10 20:02:54 2018 allow ip from any to any via em1
00015 Tue Jul 10 20:02:51 2018 allow ip from any to any via lo0
00018 Tue Jul 10 20:01:25 2018 divert 8668 ip from any to any in via em0
00080                         skipto 800 icmp from any to any out via em0 keep-state :default
00120                         skipto 800 ip from any to t.t.t.0/24 3389 out via em0 setup keep-state :default
00121                         skipto 800 ip from t.t.t.0/24 to any 3389 in via em0
00122                         deny ip from any to any 3389 in via em0
00700 Tue Jul 10 20:01:25 2018 deny log ip from any to any in via em0
шлюз на 192.168.50.20 был 192.168.20.98
для эксперимента поменял на 192.168.20.99
и вот результат , но RDP нет
dos@vis:/home/deos/forward_port# tcpdump -i em1 port 3389
listening on em1, link-type EN10MB (Ethernet), capture size 262144 bytes
20:39:02.758404 IP t.t.t.248.1312 > 192.168.50.20.rdp: Flags [S], seq 1695610262, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
20:39:02.758819 IP 192.168.50.20.rdp > t.t.t.248.1312: Flags [S.], seq 1719965283, ack 1695610263, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
20:39:05.757407 IP 192.168.50.20.rdp > t.t.t.248.1312: Flags [S.], seq 1719965283, ack 1695610263, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
20:39:05.759258 IP t.t.t.248.1312 > 192.168.50.20.rdp: Flags [S], seq 1695610262, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
20:39:11.757657 IP 192.168.50.20.rdp > t.t.t.248.1312: Flags [S.], seq 1719965283, ack 1695610263, win 8192, options [mss 1460,nop,nop,sackOK], length 0
20:39:11.762247 IP t.t.t.248.1312 > 192.168.50.20.rdp: Flags [S], seq 1695610262, win 8192, options [mss 1460,nop,nop,sackOK], length 0
20:39:32.361786 IP t.t.t.248.1316 > 192.168.50.20.rdp: Flags [S], seq 1058882110, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
20:39:32.362028 IP 192.168.50.20.rdp > t.t.t.248.1316: Flags [S.], seq 3438164068, ack 1058882111, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
20:39:35.360440 IP t.t.t.248.1316 > 192.168.50.20.rdp: Flags [S], seq 1058882110, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
20:39:35.363608 IP 192.168.50.20.rdp > t.t.t.248.1316: Flags [S.], seq 3438164068, ack 1058882111, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
20:39:41.363453 IP t.t.t.248.1316 > 192.168.50.20.rdp: Flags [S], seq 1058882110, win 8192, options [mss 1460,nop,nop,sackOK], length 0
20:39:41.368859 IP 192.168.50.20.rdp > t.t.t.248.1316: Flags [S.], seq 3438164068, ack 1058882111, win 8192, options [mss 1460,nop,nop,sackOK], length 0
как видно
подменить SRC адрес «вопрощающего»
не получилось
RDP не работает.
При этом в сети 192.168.50.0/24 RDP работает
Подскажите пожалуйста, чего я не так сделал
Re: natd RDP
Сообщение root » 11 июл 2018, 08:34
dimondack писал(а):для эксперимента поменял на 192.168.20.99
Не ясно откуда взялась 20я подсеть. Если опечатка и шлюз все же 50.99, то двойной нат тут тогда и не нужен.
dimondack писал(а):чего я не так сделал
1. Смотрим:
dimondack писал(а):00122                         deny ip from any to any 3389 in via em0
А где разрешающие правила ? О них гласит статья:
Не лишним будет добавить разрешающие правила, например если у вас firewall закрытого типа:
ipfw add 720 allow tcp from any to 10.0.2.18 80
ipfw add 730 allow tcp from 10.0.2.18 80 to any
2. Сравниваем это:
dimondack писал(а):ipfw add 12 divert 8671 tcp from any to 192.168.50.99 dst-port 3389
С вариантом из статьи:
ipfw add 705 divert 8671 tcp from any to 10.0.2.18 dst-port 80
Ничего не напрягает ? ;)
3. Так же ты не обратил внимание на нумерацию правил, а номера правил выделены жирным, что как бы намекает на важность расстановки правил.
4. Так же статья же гласит:
Если у вас возникнут проблемы, то траблшутинг начните с просмотра tcpdump, добавлением ключа -v к запуску natd, добавив слово log в добавленные правила ipfw.
Все делал ?
P.S. Смотри хотя бы вывод ipfw show, а не list, т.к. show показывает счетчики на правилах и становится хоть чуть понятно отрабатывают эти правила или нет.
Re: natd RDP
Сообщение dimondack » 12 июл 2018, 18:51
Да, опечатка была.
шлюзом назначаю em1 = 192.168.50.99
и ошибки были.
все будет исправлено.. и учтено :)
взгляд со стороны всегда полезен.
Re: natd RDP
Сообщение root » 13 июл 2018, 08:27
Научить как меньше косячить в подобных ситуациях ? ;)
    1. Берем и копируем все правила из статьи в файл.
    2. Открываем файл миднайт командером (mcedit).
    3. Устанавливаем курсор в начало файла и жмем F4.
    4. В строке поиска вводим 10.0.2.18, в строке замены 192.168.50.20 и жмем "Дальше".
    5. Устанавливаем курсор в начало файла и жмем F4.
    6. В строке поиска вводим 10.0.2.2, в строке замены 192.168.50.99 и жмем "Дальше".
    7. Устанавливаем курсор в начало файла и жмем F4.
    8. В строке поиска вводим 8080, в строке замены 3389 и жмем "Дальше".
    9. Устанавливаем курсор в начало файла и жмем F4.
    10. В строке поиска вводим 80, в строке замены 3389 и жмем "Дальше".
    11. Устанавливаем курсор в начало файла и жмем F4.
    12. В строке поиска вводим 8.8.8.8, в строке замены x.x.x.158 и жмем "Дальше".
После чего сохраняем по F2 и получаем готовый к применению файл с правилами в которых, вероятно, нужно поправить только их номера (сохраняя порядок) под реалии своего фаирвола.
Re: natd RDP
Сообщение dimondack » 14 июл 2018, 00:27
Сказано - Сделано
dos@vis:/home/dos/forward_port# cat 900.sh
#!/bin/sh
natd -p 8670 -s -m -a xxxxxxxxx.158 -redirect_port tcp 192.168.50.20:3389 3389
ipfw add 2 divert 8670 tcp from any to xxxxxxxxx.158 3389
ipfw add 10 divert 8670 tcp from 192.168.50.20 3389 to any
ipfw add 11 allow  tcp from any to 192.168.50.20 3389
ipfw add 12 allow  tcp from 192.168.50.20 3389 to any
root@vis:/home/dos # tcpdump -i em1 port 3389
20:54:19.018364 IP ttttttttt.209.2384 > 192.168.50.20.rdp: Flags [S], seq 688414354, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
20:54:19.018744 IP 192.168.50.20.rdp > ttttttttt.209.2384: Flags [S.], seq 3947250430, ack 688414355, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
20:54:22.013831 IP ttttttttt.209.2384 > 192.168.50.20.rdp: Flags [S], seq 688414354, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
20:54:22.020645 IP 192.168.50.20.rdp > ttttttttt.209.2384: Flags [S.], seq 3947250430, ack 688414355, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
20:54:28.018040 IP ttttttttt.209.2384 > 192.168.50.20.rdp: Flags [S], seq 688414354, win 8192, options [mss 1460,nop,nop,sackOK], length 0
20:54:28.018904 IP 192.168.50.20.rdp > ttttttttt.209.2384: Flags [S.], seq 3947250430, ack 688414355, win 8192, options [mss 1460,nop,nop,sackOK], length 0
не.. непорядок
чужим нечего тут делать, ходят тут всякие.. :)
#!/bin/sh
natd -p 8670 -s -m -a xxxxxxxxxx.158 -redirect_port tcp 192.168.50.20:3389 3389
ipfw add 2 divert 8670 tcp from any to xxxxxxxxxx.158 3389
ipfw add 5 divert 8671 tcp from any to 192.168.50.20 dst-port 3389
ipfw add 6 divert 8671 tcp from 192.168.50.20 3389 to 192.168.50.99
20:59:42.176867 IP 192.168.50.99.2391 > 192.168.50.20.rdp: Flags [S], seq 1748698112, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
20:59:42.177284 IP 192.168.50.20.rdp > 192.168.50.99.2391: Flags [S.], seq 4249666264, ack 1748698113, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
20:59:45.176866 IP 192.168.50.99.2391 > 192.168.50.20.rdp: Flags [S], seq 1748698112, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
20:59:45.180635 IP 192.168.50.20.rdp > 192.168.50.99.2391: Flags [S.], seq 4249666264, ack 1748698113, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
20:59:51.177903 IP 192.168.50.20.rdp > 192.168.50.99.2391: Flags [S.], seq 4249666264, ack 1748698113, win 8192, options [mss 1460,nop,nop,sackOK], length 0
20:59:51.177972 IP 192.168.50.99.2391 > 192.168.50.20.rdp: Flags [S], seq 1748698112, win 8192, options [mss 1460,nop,nop,sackOK], length 0
dos@vis:/home/dos/forward_port# ipfw sh
ipfw: DEPRECATED: 'sh' matched 'show' as a sub-string
00002   3   152 divert 8670 tcp from any to xxxxxxxxxx.158 3389
00005   6   304 divert 8671 tcp from any to 192.168.50.20 3389
00006   3   152 divert 8671 tcp from 192.168.50.20 3389 to 192.168.50.99
00010   6   304 divert 8670 tcp from 192.168.50.20 3389 to any
00011   6   304 allow tcp from any to 192.168.50.20 3389
00012   3   152 allow tcp from 192.168.50.20 3389 to any
вот теперь порядок
00002   3   152 divert 8670 tcp from any to xxxxxxxxx.158 3389
00014 877 80411 allow ip from any to any via em1
00015  24  1200 allow ip from any to any via lo0
00018   4   231 divert 8668 ip from any to any in via em0
00019   0     0 check-state :default
00020   0     0 skipto 800 tcp from any to xxxxxxxxxx 53 out via em0 setup keep-state :default
00021   2   179 skipto 800 udp from any to xxxxxxxxxx 53 out via em0 keep-state :default
00022   0     0 skipto 800 tcp from any to 8.8.8.8 53 out via em0 setup keep-state :default
00023   0     0 skipto 800 udp from any to 8.8.8.8 53 out via em0 keep-state :default
00040   0     0 skipto 800 tcp from any to any 80 out via em0 setup keep-state :default
00070   0     0 skipto 800 tcp from me to any out via em0 setup uid root keep-state :default
00080   0     0 skipto 800 icmp from any to any out via em0 keep-state :default
00330   0     0 deny ip from any to any frag in via em0
00332   0     0 deny tcp from any to any established in via em0
00415   0     0 allow tcp from tttttttt.0/24 to any 22 in via em0 setup limit src-addr 5 :default
00421   0     0 deny tcp from any to any 22 in via em0
00700   3   124 deny log logamount 5 ip from any to any in via em0
00750   3   152 deny log logamount 5 ip from any to any out via em0
00800   1    72 divert 8668 ip from any to any out via em0
01001   2   179 allow ip from any to any
65535   0     0 deny ip from any to any
21:20:19.178478 IP 192.168.50.99.3342 > 192.168.50.20.rdp: Flags [S], seq 661892658, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
21:20:19.178863 IP 192.168.50.20.rdp > 192.168.50.99.3342: Flags [S.], seq 1519783129, ack 661892659, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
21:20:22.177836 IP 192.168.50.99.3342 > 192.168.50.20.rdp: Flags [S], seq 661892658, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
21:20:22.178269 IP 192.168.50.20.rdp > 192.168.50.99.3342: Flags [S.], seq 1519783129, ack 661892659, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
21:20:28.175857 IP 192.168.50.99.3342 > 192.168.50.20.rdp: Flags [S], seq 661892658, win 8192, options [mss 1460,nop,nop,sackOK], length 0
21:20:28.178532 IP 192.168.50.20.rdp > 192.168.50.99.3342: Flags [S.], seq 1519783129, ack 661892659, win 8192, options [mss 1460,nop,nop,sackOK], length 0
Приехали
6 packets captured
371 packets received by filter
0 packets dropped by kernel
root@vis:/home/dos # tcpdump -i em0 port 3389
listening on em0, link-type EN10MB (Ethernet), capture size 262144 bytes
21:20:58.503063 IP tttttttt.209.3346 > xxxxxxxxx.158.rdp: Flags [S], seq 3229552723, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
21:21:01.502081 IP tttttttt.209.3346 > xxxxxxxxx.158.rdp: Flags [S], seq 3229552723, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
21:21:07.502213 IP tttttttt.209.3346 > xxxxxxxxx.158.rdp: Flags [S], seq 3229552723, win 8192, options [mss 1460,nop,nop,sackOK], length 0
Дописал обратку 00011 allow tcp from me 3389 to tttttttt.0/24
dos@vis:/home/dos/forward_port# ./946.sh
natd: Unable to bind divert socket.: Address already in use
00002 divert 8670 tcp from tttttttt.0/24 to xxxxxxx.158 3389
00005 divert 8671 tcp from any to 192.168.50.20 3389
00006 divert 8671 tcp from 192.168.50.20 3389 to 192.168.50.99
00008 divert 8670 tcp from 192.168.50.20 3389 to any
00009 allow tcp from any to 192.168.50.20 3389
00010 allow tcp from 192.168.50.20 3389 to any
и полилось Ваше сиятельство :D
23:57:18.764197 IP tttttttt.3338 > xxxxxxx.158.rdp: Flags [S], seq 2853111757, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
23:57:18.764791 IP xxxxxxx.158.rdp > tttttttt.3338: Flags [S.], seq 1123014669, ack 2853111758, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
23:57:18.765904 IP tttttttt.3338 > xxxxxxx.158.rdp: Flags [.], ack 1, win 16425, length 0
23:57:18.767849 IP tttttttt.3338 > xxxxxxx.158.rdp: Flags [P.], seq 1:20, ack 1, win 16425, length 19
23:57:18.768430 IP xxxxxxx.158.rdp > tttttttt.3338: Flags [P.], seq 1:20, ack 20, win 256, length 19
23:57:18.799863 IP tttttttt.3338 > xxxxxxx.158.rdp: Flags [P.], seq 20:207, ack 20, win 16420, length 187
23:57:18.800558 IP xxxxxxx.158.rdp > tttttttt.3338: Flags [P.], seq 20:848, ack 207, win 255, length 828
23:57:18.803006 IP tttttttt.3338 > xxxxxxx.158.rdp: Flags [P.], seq 207:533, ack 848, win 16213, length 326
23:57:18.809828 IP xxxxxxx.158.rdp > tttttttt.3338: Flags [P.], seq 848:907, ack 533, win 254, length 59
23:57:18.880023 IP tttttttt.3338 > xxxxxxx.158.rdp: Flags [P.], seq 533:618, ack 907, win 16198, length 85
23:57:18.880882 IP xxxxxxx.158.rdp > tttttttt.3338: Flags [P.], seq 907:1136, ack 618, win 254, length 229
23:57:18.885084 IP tttttttt.3338 > xxxxxxx.158.rdp: Flags [P.], seq 618:1407, ack 1136, win 16141, length 789
Re: natd RDP
Сообщение dimondack » 10 авг 2018, 14:38
Немного не по теме
:D :D :D
Пробовал pptp, в моём случае не заработало.
Скорее всего из-за моего домашнего провайдера
счётчики GRE на сервере только в одну(мою) сторону показывают
,а от меня по нулям.
И еще аргумент против моего провайдера - на наших внешних адресах, все работает и ipfw show показывает цифры в обе стороны, специально для этого дела разные подсети взял.
В конечном итоге собрал l2tp.
Удобная вещь.
Читал тут тему
mpd5 и l2tp (сервер VPN)
Время бежит
Re: natd RDP
Сообщение root » 10 авг 2018, 16:52
ессно, т.к. GRE и NAT это = проблема.
