FreeBSD Pipe
FreeBSD Pipe
Сообщение vasy rogov » 11 окт 2011, 12:54
Есть сервер Intel SR2600urlx. Пытаюсь сделать из него шэйпер с помощью Dummynet.
sr2600# uname -a
FreeBSD sr2600 8.2-STABLE FreeBSD 8.2-STABLE
Набор правил ipfw:
${FwCMD} add pipe 1 ip from table\(1\) to any in
${FwCMD} add pipe 2 ip from table\(2\) to any in
${FwCMD} add pipe 3 ip from table\(3\) to any in
${FwCMD} add pipe 4 ip from table\(4\) to any in
${FwCMD} add pipe 5 ip from table\(5\) to any in
${FwCMD} add pipe 6 ip from table\(6\) to any in
${FwCMD} add pipe 7 ip from table\(7\) to any in
${FwCMD} add pipe 8 ip from table\(8\) to any in
${FwCMD} add pipe 9 ip from table\(9\) to any in
${FwCMD} add pipe 10 ip from table\(10\) to any in
${FwCMD} add pipe 100 ip from table\(100\) to any in
${FwCMD} add pipe 11 ip from any to table\(1\) out
${FwCMD} add pipe 12 ip from any to table\(2\) out
${FwCMD} add pipe 13 ip from any to table\(3\) out
${FwCMD} add pipe 14 ip from any to table\(4\) out
${FwCMD} add pipe 15 ip from any to table\(5\) out
${FwCMD} add pipe 16 ip from any to table\(6\) out
${FwCMD} add pipe 17 ip from any to table\(7\) out
${FwCMD} add pipe 18 ip from any to table\(8\) out
${FwCMD} add pipe 19 ip from any to table\(9\) out
${FwCMD} add pipe 20 ip from any to table\(10\) out
${FwCMD} add pipe 101 ip from any to table\(100\) out
${FwCMD} pipe 1 config mask src-ip 0xffffffff bw 64kbit/s
${FwCMD} pipe 11 config mask dst-ip 0xffffffff bw 64kbit/s
${FwCMD} pipe 2 config mask src-ip 0xffffffff bw 128kbit/s
${FwCMD} pipe 12 config mask dst-ip 0xffffffff bw 128kbit/s
${FwCMD} pipe 3 config mask src-ip 0xffffffff bw 256kbit/s
${FwCMD} pipe 13 config mask dst-ip 0xffffffff bw 256kbit/s
${FwCMD} pipe 4 config mask src-ip 0xffffffff bw 512kbit/s
${FwCMD} pipe 14 config mask dst-ip 0xffffffff bw 512kbit/s
${FwCMD} pipe 5 config mask src-ip 0xffffffff bw 1024kbit/s
${FwCMD} pipe 15 config mask dst-ip 0xffffffff bw 1024kbit/s
${FwCMD} pipe 6 config mask src-ip 0xffffffff bw 2048bit/s
${FwCMD} pipe 16 config mask dst-ip 0xffffffff bw 2048bit/s
${FwCMD} pipe 7 config mask src-ip 0xffffffff bw 3072kbit/s queue 50KBytes
${FwCMD} pipe 17 config mask dst-ip 0xffffffff bw 3072kbit/s queue 50KBytes
${FwCMD} pipe 8 config mask src-ip 0xffffffff bw 4096bit/s
${FwCMD} pipe 18 config mask dst-ip 0xffffffff bw 4096bit/s
${FwCMD} pipe 9 config mask src-ip 0xffffffff bw 5120kbit/s
${FwCMD} pipe 19 config mask dst-ip 0xffffffff bw 5120kbit/s
${FwCMD} pipe 10 config mask src-ip 0xffffffff bw 10240kbit/s
${FwCMD} pipe 20 config mask dst-ip 0xffffffff bw 10240kbit/s
${FwCMD} pipe 100 config mask src-ip 0xffffffff bw 64kbit/s
${FwCMD} pipe 101 config mask dst-ip 0xffffffff bw 64kbit/s
Клиентов пока порядка ~400, на клиента выделяется сеть/30, в таблицу сеткой и добавляются.
Проблема в том, что когда включаю ipfw перестает ходить интернет, при пинге клиентских ипов пишет "ping: sendto: No buffer space available". При попытке пинга клиентом "мир" по tcpdump'у вижу эхо-регуест и эхо-ансвер, но клиент утверждает что у него пинг отвечает "превышен интервал.."
В час пик на роутере статистика:
sr2600# netstat -dhw1
            input        (Total)           output
   packets  errs idrops      bytes    packets  errs      bytes colls drops
      129k     0     0        89M       134k     0        92M     0     0
      140k     0     0       101M       145k     0       105M     0     0
      149k     0     0       105M       154k     0       108M     0     0
      143k     0     0       104M       147k     0       108M     0     0
      134k     0     0        95M       138k     0        98M     0     0
      142k     0     0       103M       146k     0       106M     0     0
      126k     0     0        87M       130k     0        90M     0     0
      147k     0     0       102M       152k     0       106M     0     0
      143k     0     0       100M       149k     0       104M     0     0
      142k     0     0       103M       146k     0       107M     0     0
      137k     0     0        97M       142k     0       100M     0     0
      128k     0     0        88M       133k     0        92M     0     0
sr2600# top -SIP
last pid: 42195;  load averages:  1.28,  1.15,  1.08        up 32+14:10:25  13:40:15
230 processes: 19 running, 154 sleeping, 57 waiting
CPU 0:   0.0% user,  0.0% nice,  0.6% system,  8.4% interrupt, 91.0% idle
CPU 1:   0.0% user,  0.0% nice,  0.6% system, 11.2% interrupt, 88.2% idle
CPU 2:   0.0% user,  0.0% nice,  0.0% system, 11.8% interrupt, 88.2% idle
CPU 3:   0.0% user,  0.0% nice,  0.0% system, 13.5% interrupt, 86.5% idle
CPU 4:   0.0% user,  0.0% nice,  2.2% system,  0.0% interrupt, 97.8% idle
CPU 5:   2.3% user,  0.0% nice,  1.1% system,  0.0% interrupt, 96.6% idle
CPU 6:   0.0% user,  0.0% nice,  4.5% system,  0.0% interrupt, 95.5% idle
CPU 7:   0.0% user,  0.0% nice,  6.2% system,  0.0% interrupt, 93.8% idle
CPU 8:   0.0% user,  0.0% nice,  7.9% system,  0.0% interrupt, 92.1% idle
CPU 9:   0.0% user,  0.0% nice,  1.1% system,  0.0% interrupt, 98.9% idle
CPU 10:  0.0% user,  0.0% nice,  6.7% system,  0.0% interrupt, 93.3% idle
CPU 11:  0.6% user,  0.0% nice,  4.5% system,  0.0% interrupt, 94.9% idle
CPU 12:  0.0% user,  0.0% nice,  0.0% system,  0.0% interrupt,  100% idle
CPU 13:  0.0% user,  0.0% nice,  0.0% system,  0.0% interrupt,  100% idle
CPU 14:  0.0% user,  0.0% nice,  0.0% system,  0.0% interrupt,  100% idle
CPU 15:  0.0% user,  0.0% nice,  0.0% system,  5.6% interrupt, 94.4% idle
Mem: 282M Active, 664M Inact, 767M Wired, 164K Cache, 821M Buf, 6109M Free
Swap: 4096M Total, 4096M Free
  PID USERNAME  THR PRI NICE   SIZE    RES STATE   C   TIME   WCPU COMMAND
   11 root       16 171 ki31     0K   256K CPU0    0    ??? 1548.05% idle
   12 root       57 -68    -     0K   912K WAIT    3 240.9H 56.25% intr
    0 root       35 -68    0     0K   544K -      12 143.3H 37.55% kernel
59894 bind        1  45    0   106M   104M kqread 11 527:36  3.96% named
17045 root        1  45    0   300M   294M select  9 293:44  2.20% bgpd
Поллинг не включен.
На сколько я понимаю это происходит потому, что забиваются очереди пайпов, но при такой же конфигурации должно выделяться на каждый ип своя очередь/пайп или же все таки получается, что на каждую таблицу именно один пайп выделяется с одной очередью пакетов на всех? Ведь если бы на каждого клиента выделялся бы свой пайп, не могут же все разом свои очереди забить...
ЗЫ сумбурно, но смысл уловить можно, а так ниид хелп :)
vasy rogov
Re: FreeBSD Pipe
Сообщение root » 12 окт 2011, 10:04
показывай выводы команд:
sysctl net.inet.ip.fw.one_pass
ipfw show
ipfw pipe list
Re: FreeBSD Pipe
Сообщение Андрей » 12 окт 2011, 12:01
vasy rogov писал(а):Проблема в том, что когда включаю ipfw перестает ходить интернет, при пинге клиентских ипов пишет "ping: sendto: No buffer space available".
Не так давно устанавливал еще 1 сервер доступа, подобное сообщение получал от того, что не правильно настроил "датчик" биллинговой системы. Он должен добавлять или удалять правило хождения абона в "мир". Правило было сделано на отказ.
Re: FreeBSD Pipe
Сообщение vasy rogov » 12 окт 2011, 15:28
net.inet.ip.fw.one_pass: 1
Про это я уже думал, спецом стоит 1 что бы в следующий пайп не пападали пакеты.
ipfw show
00100            0               0 pipe 1 ip from table(1) to any in
00200            0               0 pipe 2 ip from table(2) to any in
00300            0               0 pipe 3 ip from table(3) to any in
00400            0               0 pipe 4 ip from table(4) to any in
00500            0               0 pipe 5 ip from table(5) to any in
00600            0               0 pipe 6 ip from table(6) to any in
00700            0               0 pipe 7 ip from table(7) to any in
00800            0               0 pipe 8 ip from table(8) to any in
00900        16151         3546471 pipe 9 ip from table(9) to any in
01000            0               0 pipe 10 ip from table(10) to any in
01100            0               0 pipe 100 ip from table(100) to any in
01200            0               0 pipe 11 ip from any to table(1) out
01300            0               0 pipe 12 ip from any to table(2) out
01400            0               0 pipe 13 ip from any to table(3) out
01500            0               0 pipe 14 ip from any to table(4) out
01600            0               0 pipe 15 ip from any to table(5) out
01700            0               0 pipe 16 ip from any to table(6) out
01800            0               0 pipe 17 ip from any to table(7) out
01900            0               0 pipe 18 ip from any to table(8) out
02000        22458        26576659 pipe 19 ip from any to table(9) out
02100            0               0 pipe 20 ip from any to table(10) out
02200            0               0 pipe 101 ip from any to table(100) out
65535 164452240935 117060508793366 allow ip from any to any
ipfw pipe list
00001:  64.000 Kbit/s    0 ms burst 0
q131073  50 sl. 0 flows (1 buckets) sched 65537 weight 0 lmax 0 pri 0 droptail
 sched 65537 type FIFO flags 0x1 100 buckets 0 active
    mask:  0x00 0xffffffff/0x0000 -> 0x00000000/0x0000
BKT Prot ___Source IP/port____ ____Dest. IP/port____ Tot_pkt/bytes Pkt/Byte Drp
00002: 128.000 Kbit/s    0 ms burst 0
q131074  50 sl. 0 flows (1 buckets) sched 65538 weight 0 lmax 0 pri 0 droptail
 sched 65538 type FIFO flags 0x1 100 buckets 0 active
00003: 256.000 Kbit/s    0 ms burst 0
q131075  50 sl. 0 flows (1 buckets) sched 65539 weight 0 lmax 0 pri 0 droptail
 sched 65539 type FIFO flags 0x1 100 buckets 0 active
00004: 512.000 Kbit/s    0 ms burst 0
q131076  50 sl. 0 flows (1 buckets) sched 65540 weight 0 lmax 0 pri 0 droptail
 sched 65540 type FIFO flags 0x1 100 buckets 0 active
00005:   1.024 Mbit/s    0 ms burst 0
q131077  50 sl. 0 flows (1 buckets) sched 65541 weight 0 lmax 0 pri 0 droptail
 sched 65541 type FIFO flags 0x1 100 buckets 0 active
00006:   2.048 Kbit/s    0 ms burst 0
q131078  50 sl. 0 flows (1 buckets) sched 65542 weight 0 lmax 0 pri 0 droptail
 sched 65542 type FIFO flags 0x1 100 buckets 0 active
00007:   3.072 Mbit/s    0 ms burst 0
q131079 50 KB 0 flows (1 buckets) sched 65543 weight 0 lmax 0 pri 0 droptail
 sched 65543 type FIFO flags 0x1 100 buckets 0 active
00008:   4.096 Kbit/s    0 ms burst 0
q131080  50 sl. 0 flows (1 buckets) sched 65544 weight 0 lmax 0 pri 0 droptail
 sched 65544 type FIFO flags 0x1 100 buckets 0 active
00009:   5.120 Mbit/s    0 ms burst 0
q131081  50 sl. 0 flows (1 buckets) sched 65545 weight 0 lmax 0 pri 0 droptail
 sched 65545 type FIFO flags 0x1 100 buckets 1 active
223 ip      х.х.х.2/0             0.0.0.0/0     5691  5976942  0    0 195
00010:  10.240 Mbit/s    0 ms burst 0
q131082  50 sl. 0 flows (1 buckets) sched 65546 weight 0 lmax 0 pri 0 droptail
 sched 65546 type FIFO flags 0x1 100 buckets 0 active
00011:  64.000 Kbit/s    0 ms burst 0
q131083  50 sl. 0 flows (1 buckets) sched 65547 weight 0 lmax 0 pri 0 droptail
 sched 65547 type FIFO flags 0x1 100 buckets 0 active
    mask:  0x00 0x00000000/0x0000 -> 0xffffffff/0x0000
00012: 128.000 Kbit/s    0 ms burst 0
q131084  50 sl. 0 flows (1 buckets) sched 65548 weight 0 lmax 0 pri 0 droptail
 sched 65548 type FIFO flags 0x1 100 buckets 0 active
00013: 256.000 Kbit/s    0 ms burst 0
q131085  50 sl. 0 flows (1 buckets) sched 65549 weight 0 lmax 0 pri 0 droptail
 sched 65549 type FIFO flags 0x1 100 buckets 0 active
00014: 512.000 Kbit/s    0 ms burst 0
q131086  50 sl. 0 flows (1 buckets) sched 65550 weight 0 lmax 0 pri 0 droptail
 sched 65550 type FIFO flags 0x1 100 buckets 0 active
00015:   1.024 Mbit/s    0 ms burst 0
q131087  50 sl. 0 flows (1 buckets) sched 65551 weight 0 lmax 0 pri 0 droptail
 sched 65551 type FIFO flags 0x1 100 buckets 0 active
00017:   3.072 Mbit/s    0 ms burst 0
q131089 50 KB 0 flows (1 buckets) sched 65553 weight 0 lmax 0 pri 0 droptail
 sched 65553 type FIFO flags 0x1 100 buckets 0 active
00016:   2.048 Kbit/s    0 ms burst 0
q131088  50 sl. 0 flows (1 buckets) sched 65552 weight 0 lmax 0 pri 0 droptail
 sched 65552 type FIFO flags 0x1 100 buckets 0 active
00019:   5.120 Mbit/s    0 ms burst 0
q131091  50 sl. 0 flows (1 buckets) sched 65555 weight 0 lmax 0 pri 0 droptail
 sched 65555 type FIFO flags 0x1 100 buckets 1 active
181 ip           0.0.0.0/0        х.х.х.2/0     1009   520981 47 61628  10
00018:   4.096 Kbit/s    0 ms burst 0
q131090  50 sl. 0 flows (1 buckets) sched 65554 weight 0 lmax 0 pri 0 droptail
 sched 65554 type FIFO flags 0x1 100 buckets 0 active
00020:  10.240 Mbit/s    0 ms burst 0
q131092  50 sl. 0 flows (1 buckets) sched 65556 weight 0 lmax 0 pri 0 droptail
 sched 65556 type FIFO flags 0x1 100 buckets 0 active
00100:  64.000 Kbit/s    0 ms burst 0
q131172  50 sl. 0 flows (1 buckets) sched 65636 weight 0 lmax 0 pri 0 droptail
 sched 65636 type FIFO flags 0x1 100 buckets 0 active
00101:  64.000 Kbit/s    0 ms burst 0
q131173  50 sl. 0 flows (1 buckets) sched 65637 weight 0 lmax 0 pri 0 droptail
 sched 65637 type FIFO flags 0x1 100 buckets 0 active
Все показатели сняты в момент когда в таблице только один ип, не чего сейчас не "тупит", понятно что лучше бы привести показатели в момент всех забитых клиентов, но это черевато очень.... но если мыслей не будет, то сниму показания в момент "иступления"
vasy rogov
Re: FreeBSD Pipe
Сообщение lehisnoe » 12 окт 2011, 17:43
У нас есть практика не очень хорошего поведения системы при конфигурации pipe'ов, используя направление out, вследствие чего мы всегда используем только направление in с указанием ифейса.
В твоем случае, я бы попробовал переписать правила таким образом:
${FwCMD} add pipe 1 ip from table\(1\) to any via $loc in
${FwCMD} add pipe 11 ip from any to table\(1\) via $ext in
где $loc - интерфейс, смотрящий в локалку, $ext - интерфейс, смотрящий во вне.
Re: FreeBSD Pipe
Сообщение root » 13 окт 2011, 07:55
+1 к lehisnoe
я бы ещё попробовал убрать конфигурацию mask из пайпов
pipe 7004 config bw 8Kbit/s
pipe 7005 config bw 18Kbit/s
и посмотрел бы себя тачка ощущала при таком варианте
Re: FreeBSD Pipe
Сообщение vasy rogov » 13 окт 2011, 16:44
Проблема в том, что на каждого клиента выделяется влан, соответственно придется перечислить все вланы, на выход проще - всего два.
root писал(а):я бы ещё попробовал убрать конфигурацию mask из пайпов
А разве тогда не получится, что на каждую таблицу будет создан один пайп и скорость будет у всех ипов сумарная?
vasy rogov
Re: FreeBSD Pipe
Сообщение root » 14 окт 2011, 07:27
vasy rogov писал(а):что на каждого клиента выделяется влан, соответственно придется перечислить все вланы
зачем перечислять все, если можно указать по маске:
via vlan* in
