DNS и 2-ве разные МХ записи
Сообщение Parafin OL » 08 июл 2008, 17:09
вообщем так есть доменое имя kuks.com, проплачено и работает до нового года
меняем на pups-corp.com, новое на него переходим
то и то должно работать,
options {
        directory       "/etc/namedb";
        pid-file        "/var/run/named/pid";
        dump-file       "/var/dump/named_dump.db";
        statistics-file "/var/stats/named.stats";
   query-source address * port 53;
        listen-on {
                127.0.0.1;
                192.168.1.1;
        217.24.*.*;
   forwarders {192.168.1.253;
logging {
    channel default {
    file "/var/log/named.log";
    severity info;
    print-time yes;
    print-category yes;
channel database {
    file "/var/log/database.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel security {
    file "/var/log/security.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel resolver {
    file "/var/log/resolver.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel xfer-in {
    file "/var/log/xfer-in.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel xfer-out {
    file "/var/log/xfer-out.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel notify {
    file "/var/log/notify.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel client {
    file "/var/log/client.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel update {
    file "/var/log/update.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel queries {
    file "/var/log/queries.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel dispatch {
    file "/var/log/dispatch.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel dnssec {
    file "/var/log/dnssec.log" ;
    severity info;
    print-time yes;
    print-category yes;
channel lame-servers {
    file "/var/log/lame-servers.log" ;
    severity info;
    print-time yes;
    print-category yes;
    category default        { default; };
    category general        { default; };
    category unmatched      { default; };
    category network        { default; };
    category config         { default; };
    category database       { database; };
    category security       { security; };
    category resolver       { resolver; };
    category xfer-in        { xfer-in; };
    category xfer-out       { xfer-out; };
    category notify         { notify; };
    category client         { client; };
    category update         { update; };
    category queries        { queries; };
    category dispatch       { dispatch; };
    category dnssec         { dnssec; };
    category lame-servers   { lame-servers; };
acl corp_networks {
       192.168.1.0/24;
       192.168.3.0/24;
       192.168.5.0/24;
       192.168.7.0/24;
       192.168.9.0/24;
       192.168.11.0/24;
       192.168.15.0/24;
       192.168.17.0/24;
       192.168.23.0/24;
view corp_net {
    match-clients {
   corp_networks;
   127.0.0.1;
    zone "." {
        type hint;
        file "named.root";
    zone "0.0.127.IN-ADDR.ARPA" {
        type master;
        file "master/localhost.rev";
    zone "kuks.com" {
        type master;
        file "master/corp_view/kuks.com";
   allow-transfer {
       192.168.1.253;
       192.168.3.1;
       192.168.11.1;
       192.168.15.1;
       192.168.17.1;
       192.168.23.1;
    zone "local.net" {
        type slave;
        file "slave/local.net";
        masters {
                192.168.1.3;
    zone "kdp.net" {
        type slave;
        file "slave/kdp.net";
        masters {
                192.168.5.2;
    zone "lviv.kuks.com" {
        type forward;
        forwarders {
           192.168.11.1;
    zone "kharkiv.kuks.com" {
        type forward;
        forwarders {
           192.168.15.1;
    zone "kiev.kuks.com" {
        type forward;
        forwarders {
           192.168.3.1;
    zone "lit.kuks.com" {
        type forward;
        forwarders {
           192.168.17.1;
    zone "msk.kuks.com" {
        tape forward;
   forwarders {
           192.168.23.1;
    zone "1.168.192.in-addr.arpa" {
        type slave;
        file "slave/1.168.192.in-addr.arpa";
        masters {
                192.168.1.3;
    zone "17.168.192.in-addr.arpa" {
        type slave;
        file "slave/17.168.192.in-addr.arpa";
        masters {
                192.168.17.2;
    zone "15.168.192.in-addr.arpa" {
        type slave;
        file "slave/15.168.192.in-addr.arpa";
        masters {
                192.168.15.2;
    zone "5.168.192.in-addr.arpa" {
        type slave;
        file "slave/5.168.192.in-addr.arpa";
        masters {
                192.168.5.2;
    zone "3.168.192.in-addr.arpa" {
        type slave;
        file "slave/3.168.192.in-addr.arpa";
        masters {
                192.168.3.54;
    zone "23.168.192.in-addr.arpa" {
         type slave;
    file "slave/23.168.192.192.in.addr.arpa" {
    masters {
            192.168.23.2;
view external {
    match-clients {
   0.0.0.0/0;
    zone "kuks.com" {
   type master;
   file "master/kuks.com";
   allow-transfer {
       195.95.*.*;
       62.*.*.*;
       82.207.*.*;
       82.207.*.*;
       83.220.*.*;
   type slave;
   file "slave/kharkiv.kuks.com";
   masters {
       82.207.*.*;
   type slave;
   file "slave/kiev.kuks.com";
   masters {
       195.95.*.*;
   type slave;
   file "slave/lviv.kuks.com";
   masters {
       62.221.*.*;
   type slave;
   file "slave/lit.kuks.com";
   masters {
       82.207.*.*;
        type slave;
        file "slave/msk.kuks.com";
   masters {
       83.200.*.*;
и как и что добавить pups-corp.com
Parafin OL
Re: DNS и 2-ве разные МХ записи
Сообщение root » 08 июл 2008, 17:34
1. Твой DNS ипользует view, это когда хостам выдается имя в соответствии с IP-адресом откуда пришел запрос.
В твоем случае это:
все IP-адреса из corp_networks получают имена из файла зоны master/corp_view/kuks.com
а все остальные из master/kuks.com
2. Для выполнения твоей задачи тебе нужно создать файл зоны для домена pups-corp.com
Т.к. я думаю, что, скорее всего, все остальные хосты в зоне kuks.com тоже переедут в домен pups-corp.com, то:
берем и копируем файлы:
master/corp_view/kuks.com в master/corp_view/pups-corp.com
master/kuks.com в master/pups-corp.com
далее все где в файлах зоны встречается kuks.com меняй на pups-corp.com (если запостишь тут файлы зоны, то скажу точнее)
далее в секцию view corp_net добавляешь:
 zone "pups-corp.com" {
        type master;
        file "master/corp_view/pups-corp.com";
   allow-transfer {
       192.168.1.253;
       192.168.3.1;
       192.168.11.1;
       192.168.15.1;
       192.168.17.1;
       192.168.23.1;
а в секцию view external добаляешь:
   type master;
   file "master/pups-corp.com";
   allow-transfer {
       195.95.*.*;
       62.*.*.*;
       82.207.*.*;
       82.207.*.*;
       83.220.*.*;
при добавлении будь внимателен, соблюдай фигурные скобки секций
перезапускаешь DNS и смотришь в лог /var/log/named.log при условии что в syslog.conf описан named
и я бы на твоем месте использовал бы rndc в кач-ве управления сервисом named (перезапуск и т.п.)
если что то ещё не понятно - спрашивай.
Сообщение Parafin OL » 08 июл 2008, 17:54
pups-corp.com создать в /var/named/etc/namedb/master/corp_view/pups-corp.com
мне нужно чтобы тот и тот работал
Parafin OL
Сообщение Parafin OL » 08 июл 2008, 17:59
но у меня еще и тачка называется где поднят ДНС gund.kuks.com что с этим делать?
Parafin OL
Сообщение root » 08 июл 2008, 18:03
да, создавать там, а /etc/namedb это скорее всего симлинк на /var/named/etc/namedb
они и будут оба работать, ты же не трогаешь named.conf для kuks.com и его зоны
зоны ты копируешь в новый файл и изменяешь скопированный, а не старый
и в named.conf ты добавляешь, а не заменяешь
покажи "шапку" файла master/kuks.com и master/corp_view/pups-corp.com
например:
$TTL    3600
@       IN      SOA     ns.subnets.ru. root.subnets.ru.   (
                                2008062502; Serial
                                3600    ; Refresh
                                900     ; Retry
                                3600000 ; Expire
                                3600 )  ; Minimum
                IN      NS      ns.subnets.ru.
                IN      NS      ns2.subnets.ru.
                IN      MX      10 mail
localhost       IN      A       127.0.0.1
subnets.ru.     IN      A       217.172.16.77
ns              IN      A       217.172.16.77
ns2             IN      A       217.172.16.1
mail            IN      A       217.172.16.77
Сообщение Parafin OL » 08 июл 2008, 18:12
Вот master/kuks.com.
$ORIGIN .
$TTL 3600   ; 1 hour
kuks.com      IN SOA   ns1.kuks.com. admin.kuks.com. (
            2007112910 ; serial
            3600       ; refresh (1 hour)
            900        ; retry (15 minutes)
            3600000    ; expire (5 weeks 6 days 16 hours)
            3600       ; minimum (1 hour)
         NS   ns1.kuks.com.
         NS   ns2.kuks.com.
         NS   ns3.kuks.com.
         A   217.*.*.*
         MX   5 mail.kuks.com.
         MX   10 mail2.kuks.com.
         MX   20 mail.lviv.kuks.com.
         MX   30 mail.kharkiv.kuks.com.
         MX   40 mail.kiev.kuks.com.
$ORIGIN kuks.com.
ftp         CNAME   mail
help         A   217.24.*.*
kharkiv         NS   ns2
kiev         NS   ns3
lviv         NS   ns4
mail         A   217.24.*.*
mail2         A   77.242.*.*
ns1         A   217.24.*.*
ns2         A   82.207.*.*
ns3         A   195.95.*.*
ns4         A   62.221.*.*
updates         A   217.24.*.*
www         A   195.248.*.*
Последний раз редактировалось Parafin OL 08 июл 2008, 18:50, всего редактировалось 1 раз.
Parafin OL
Сообщение root » 08 июл 2008, 18:38
Parafin OL писал(а):но у меня еще и тачка называется где поднят ДНС gund.kuks.com что с этим делать?
не важно как она называется, главное чтобы это имя резолвилось (т.е. по имени выдавался IP)
пока зона kuks.com прописана на этом сервере проблем не будет, можно, если что, и в /etc/hosts прописать
сменить имя легко - в rc.conf поправить строчку hostname
что бы не ребутить сервер в консоле воспользоваться командой hostname
hostname -- set or print name of current host system
Сообщение root » 08 июл 2008, 18:46
на самом деле kuks.com уже "кончился" - Record expires on 05.06.2009
копируй master/kuks.com в pups-corp.com
изменяй pups-corp.com на:
    $ORIGIN .
    $TTL 3600   ; 1 hour
    kuks.com      IN SOA   ns1.pups-corp.com. admin.pups-corp.com. (
                2008070801 ; serial
             NS   ns1.pups-corp.com.
             NS   ns2.pups-corp.com.
             NS   ns3.pups-corp.com.
             A   217.24.167.226
             MX   5 mail.pups-corp.com.
             MX   10 mail2.pups-corp.com.
             MX   20 mail.lviv.pups-corp.com.
             MX   30 mail.kharkiv.pups-corp.com.
             MX   40 mail.kiev.pups-corp.com.
    $ORIGIN pups-corp.com.
    ftp         CNAME   mail
    help         A   217.24.*.*
    kharkiv         NS   ns2
    kiev         NS   ns3
    lviv         NS   ns4
    mail         A   217.24.*.*
    mail2         A   77.242.*.*
    ns1         A   217.24.*.*
    ns2         A   82.207.*.*
    ns3         A   195.95.*.*
    ns4         A   62.221.*.*
    www         A   195.248.*.*
получишь точную копию домена kuks.com, но для pups-corp.com
не забудь добавить записи о домене pups-corp.com на вторичные сервера ns2 и ns3
тоже самое проделай для master/corp_view/pups-corp.com
иначе IP-адреса в описанные в секции corp_networks ничего не получат
Сообщение Parafin OL » 08 июл 2008, 18:49
Зделать так
$ORIGIN .
$TTL 3600   ; 1 hour
kuks.com      IN SOA   ns1. kuks.com. admin. kuks.com. (
            2007112910 ; serial     [b]номер менять?[/b]
         NS   ns1..
         NS   ns2. pups-corp.com.
         NS   ns3. pups-corp.com.
         A   217.24.*.*
         MX   5 mail. pups-corp.com.
         MX   10 mail2. pups-corp.com.
         MX   20 mail.lviv. pups-corp.com.
         MX   30 mail.kharkiv. pups-corp.com.
         MX   40 mail.kiev. pups-corp.com.
$ORIGIN kuks.com.
ftp         CNAME   mail
help         A   217.24.*.*
kharkiv         NS   ns2
kiev         NS   ns3
lviv         NS   ns4
mail         A   217.24.*.*
mail2         A   77.242.*.*
ns1         A   217.24.*.*
ns2         A   82.207.*.*
ns3         A   195.95.*.*
ns4         A   62.221.*.*
www         A   195.248.*.*
Последний раз редактировалось Parafin OL 08 июл 2008, 18:52, всего редактировалось 2 раз(а).
Parafin OL
Сообщение root » 08 июл 2008, 18:51
нет, смотри мой пример в сообщении выше.
я заменил все что нужно.
по serial DNS сервер ориентируется изменилась зона или нет.
Он обычно имеет формат: ГОДМЕСЯЦДЕНЬКОЛВОИЗМЕНЕНИЙЗАЭТОТДЕНЬ
например 2008070801 - изменен 07.08.2008 в этот день изменен 1-н раз
каждый раз что либо меняя в зоны ты жолжен увеличивать serial, т.к. часы всегда идут вперед, то все пользуются форматом даты, т.к. так ты соблюдаешь что что хочет от тебя DNS + всегда знаешь когда именно менялась зона
