RB-1:
- Код: Выделить всё
[admin@MikroTik] > /interface print
Flags: D - dynamic, X - disabled, R - running, S - slave
# NAME TYPE MTU L2MTU MAX-L2MTU
0 R ether1-gateway ether 1500 1600 4076
1 R ether2-master-local ether 1500 1598 2028
2 R ether3-slave-local ether 1500 1598 2028
3 R ether4-slave-local ether 1500 1598 2028
4 ether5-slave-local ether 1500 1598 2028
5 wlan1 wlan 1500 2290
6 R bridge-local bridge 1500 1598
7 R ;;; dyn ip: user ****** : password ****
;;; static ip: user ***** : password *****
pppoe-out1 pppoe-out 1480
8 X wlan2 wlan 1500
9 R to_tim ovpn-out 1500
- Код: Выделить всё
[admin@MikroTik] > /ip address print
Flags: X - disabled, I - invalid, D - dynamic
# ADDRESS NETWORK INTERFACE
0 ;;; default configuration
192.168.1.1/24 192.168.1.0 bridge-local
1 I 192.168.90.1/24 192.168.90.0 wlan2
2 D 192.168.10.2/32 192.168.10.1 to_tim
3 D 81.90.12.18/32 10.90.8.1 pppoe-out1
- Код: Выделить всё
[admin@MikroTik] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 10.90.8.1 1
1 ADC 10.90.8.1/32 81.90.12.18 pppoe-out1 0
2 ADC 192.168.1.0/24 192.168.1.1 bridge-local 0
3 A S 192.168.4.0/24 to_tim 1
4 ADS 192.168.10.0/29 192.168.10.1 0
5 ADC 192.168.10.1/32 192.168.10.2 to_tim 0
- Код: Выделить всё
[admin@MikroTik] > /ip firewall filter print
0 ;;; Added by webbox
chain=customer action=accept connection-state=related
1 ;;; ICMP
chain=input action=accept protocol=icmp
2 ;;; OpenVPN
chain=forward action=accept protocol=udp dst-port=1194
3 ;;; SSH
chain=input action=accept protocol=tcp dst-port=22
4 X ;;; RDP to server
chain=forward action=accept protocol=tcp dst-port=3389
5 ;;; MUNIN
chain=forward action=accept protocol=tcp src-address=178.218.212.202 dst-port=4949
6 X ;;; WinBox
chain=input action=accept protocol=tcp dst-port=8291
7 ;;; Added by webbox
chain=input action=accept connection-state=established in-interface=pppoe-out1
8 ;;; Added by webbox
chain=input action=accept connection-state=related in-interface=pppoe-out1
9 ;;; Added by webbox
chain=customer action=accept connection-state=established
10 ;;; Added by webbox
chain=forward action=jump jump-target=customer in-interface=pppoe-out1
11 ;;; Added by webbox
chain=input action=drop in-interface=pppoe-out1
12 X chain=forward action=accept src-address=192.168.4.0/24 dst-address=192.168.1.0/24
13 X chain=forward action=accept src-address=192.168.1.0/24 dst-address=192.168.4.0/24
14 ;;; Added by webbox
chain=customer action=drop
15 X chain=input action=drop src-address=192.168.90.0/24 dst-address=192.168.1.0/24
16 X chain=input action=drop src-address=192.168.1.0/24 dst-address=192.168.90.0/24
- Код: Выделить всё
[admin@MikroTik] > /ip firewall nat print
0 chain=srcnat action=accept to-addresses=0.0.0.0 dst-address=192.168.4.0/24
1 chain=srcnat action=accept src-address=192.168.4.0/24
2 ;;; Added by webbox
chain=srcnat action=masquerade out-interface=pppoe-out1
3 ;;; RDP to server
chain=dstnat action=dst-nat to-addresses=192.168.1.2 to-ports=3389 protocol=tcp dst-port=3389
4 ;;; OpenVPN
chain=dstnat action=dst-nat to-addresses=192.168.1.2 to-ports=1194 protocol=udp dst-port=1194
5 ;;; MUNIN
chain=dstnat action=dst-nat to-addresses=192.168.1.2 to-ports=4949 protocol=tcp src-address=178****.212.202 dst-port=4949
Туннель подымается
- Код: Выделить всё
[admin@MikroTik] /interface ovpn-client> /ping 192.168.10.1
HOST SIZE TTL TIME STATUS
192.168.10.1 56 64 5ms
sent=6 received=6 packet-loss=0% min-rtt=5ms avg-rtt=5ms max-rtt=5ms
- Код: Выделить всё
[admin@MikroTik] /interface ovpn-client> /ping 192.168.4.1
192.168.4.1 56 64 5ms
sent=5 received=5 packet-loss=0% min-rtt=5ms avg-rtt=5ms max-rtt=5ms
- Код: Выделить всё
[admin@MikroTik] /interface ovpn-client> /ping 192.168.4.1 src-address=192.168.1.1
packet rejected
packet rejected
packet rejected
packet rejected
packet rejected
packet rejected
packet rejected
sent=7 received=0 packet-loss=100%
При этом запуск снифера на RB-4 ни дает никаких пакетов
- Код: Выделить всё
[admin@MikroTik] /tool sniffer> quick ip-address=192.168.1.1/32
INTERFACE TIME NUM DIR SRC-MAC DST-MAC VLAN SRC-ADDRESS DST-ADDRESS PROTOCOL SIZE
Сервер в сети RB-1 пинает др сервер в сети RB-4С, снифер на RB-1 дает вот что
- Код: Выделить всё
[admin@MikroTik] /tool sniffer> quick ip-protocol=icmp ip-address=192.168.4.1
ether2... 0.188 1 <- 192.168.1.2 192.168.4.14 ip:icmp 60
bridge... 0.188 2 <- 192.168.1.2 192.168.4.14 ip:icmp 60
ether2... 5.186 3 <- 192.168.1.2 192.168.4.14 ip:icmp 60
bridge... 5.186 4 <- 192.168.1.2 192.168.4.14 ip:icmp 60
ether2... 10.184 5 <- 192.168.1.2 192.168.4.14 ip:icmp 60
bridge... 10.184 6 <- 192.168.1.2 192.168.4.14 ip:icmp 60
кто и где реджектит пакеты плз нид хел уже кончились идеи (
