низкая скорость в Site-to-Site VPN между двумя SRX-240H
Сообщение wingdog » 23 май 2011, 14:33
Здравствуйте!
подскажите пожалуйста, что нужно подправить в следующем конфиге:
routing-options {
    static {
        route 0.0.0.0/0 next-hop шлюз_провайдера;
        route 192.168.30.0/24 next-hop st0.0;
security {
    ike {
        policy ike-policy-stskuba {
            mode aggressive;
            proposal-set standard;
            pre-shared-key ascii-text "ключик"; ##
SECRET-DATA
        gateway ike-gate-stskuba {
            ike-policy ike-policy-stskuba;
            address Remote_external_IP;
            external-interface ge-0/0/0;
    ipsec {
        policy ipsec-policy-stskuba {
            perfect-forward-secrecy {
                keys group2;
        vpn ipsec-vpn-stskuba {
            bind-interface st0.0;
            ike {
                gateway ike-gate-stskuba;
                ipsec-policy ipsec-policy-stskuba;
            establish-tunnels immediately;
 show security ike security-associations detail
IKE peer Remote_IP, Index 79,
  Role: Responder, State: UP
  Initiator cookie: 15bf76752c6655ce, Responder cookie: c81c0009571a3fcc
  Exchange type: Aggressive, Authentication method: Pre-shared-keys
  Local: Local_IP:500, Remote: Remote_IP:500
  Lifetime: Expires in 25106 seconds
  Peer ike-id: Remote_IP
  Xauth assigned IP: 0.0.0.0
  Algorithms:
   Authentication        : sha1
   Encryption            : 3des-cbc
   Pseudo random function: hmac-sha1
 show security ipsec security-associations detail
  Virtual-system: root
  Local Gateway: Local_IP, Remote Gateway: Remote_IP
  Local Identity: ipv4_subnet(any:0,[0..7]=0.0.0.0/0)
  Remote Identity: ipv4_subnet(any:0,[0..7]=0.0.0.0/0)
    DF-bit: clear
    Direction: inbound, SPI: be197135, AUX-SPI: 0
                              , VPN Monitoring: -
    Hard lifetime: Expires in 2922 seconds
    Lifesize Remaining:  Unlimited
    Soft lifetime: Expires in 2321 seconds
    Mode: tunnel, Type: dynamic, State: installed
    Protocol: ESP, Authentication: hmac-sha1-96, Encryption: 3des-cbc
    Anti-replay service: counter-based enabled, Replay window size: 64
соотно на втором джунипере тоже самое, только с другими адресами.
проблема:
результаты iperf'а через этот туннель удручающие:
C:\jperf-2.0.0\bin>iperf.exe -c 192.168.30.5 -P 10 -n 100000000
Client connecting to 192.168.30.5, TCP port 5001
TCP window size: 8.00 KByte (default)
[1316] local 172.16.0.69 port 49536 connected with 192.168.30.5 port 5001
[1304] local 172.16.0.69 port 49535 connected with 192.168.30.5 port 5001
[1292] local 172.16.0.69 port 49534 connected with 192.168.30.5 port 5001
[1280] local 172.16.0.69 port 49533 connected with 192.168.30.5 port 5001
[1268] local 172.16.0.69 port 49532 connected with 192.168.30.5 port 5001
[1256] local 172.16.0.69 port 49531 connected with 192.168.30.5 port 5001
[1244] local 172.16.0.69 port 49530 connected with 192.168.30.5 port 5001
[1232] local 172.16.0.69 port 49529 connected with 192.168.30.5 port 5001
[1220] local 172.16.0.69 port 49528 connected with 192.168.30.5 port 5001
[1208] local 172.16.0.69 port 49527 connected with 192.168.30.5 port 5001
[ ID] Interval       Transfer     Bandwidth
[1304]  0.0-161.5 sec  95.4 MBytes  4.95 Mbits/sec
[1220]  0.0-161.7 sec  95.4 MBytes  4.95 Mbits/sec
[1268]  0.0-166.5 sec  95.4 MBytes  4.81 Mbits/sec
[1232]  0.0-167.1 sec  95.4 MBytes  4.79 Mbits/sec
[1316]  0.0-169.4 sec  95.4 MBytes  4.72 Mbits/sec
[1280]  0.0-169.6 sec  95.4 MBytes  4.72 Mbits/sec
[1256]  0.0-170.0 sec  95.4 MBytes  4.71 Mbits/sec
[1292]  0.0-172.5 sec  95.4 MBytes  4.64 Mbits/sec
[1244]  0.0-173.5 sec  95.4 MBytes  4.61 Mbits/sec
[1208]  0.0-178.9 sec  95.4 MBytes  4.47 Mbits/sec
[SUM]  0.0-178.9 sec   954 MBytes  44.7 Mbits/sec
почему удручающие - да потому что рядом стоят Windows Server 2003+ISA 2006, на которых сейчас туннели подняты и там показания совсем другие:
D:\jperf-2.0.0\bin>iperf.exe -c 192.168.0.7 -P 10 -n 100000000
Client connecting to 192.168.0.7, TCP port 5001
TCP window size: 63.0 KByte (default)
[1608] local 172.16.0.100 port 5383 connected with 192.168.0.7 port 5001
[1596] local 172.16.0.100 port 5382 connected with 192.168.0.7 port 5001
[1572] local 172.16.0.100 port 5380 connected with 192.168.0.7 port 5001
[1548] local 172.16.0.100 port 5378 connected with 192.168.0.7 port 5001
[1524] local 172.16.0.100 port 5376 connected with 192.168.0.7 port 5001
[1244] local 172.16.0.100 port 5373 connected with 192.168.0.7 port 5001
[1584] local 172.16.0.100 port 5381 connected with 192.168.0.7 port 5001
[1560] local 172.16.0.100 port 5379 connected with 192.168.0.7 port 5001
[1536] local 172.16.0.100 port 5377 connected with 192.168.0.7 port 5001
[1512] local 172.16.0.100 port 5375 connected with 192.168.0.7 port 5001
[1596]  0.0-84.5 sec  95.4 MBytes  9.47 Mbits/sec
[1244]  0.0-85.0 sec  95.4 MBytes  9.41 Mbits/sec
[1584]  0.0-85.4 sec  95.4 MBytes  9.37 Mbits/sec
[1524]  0.0-85.9 sec  95.4 MBytes  9.32 Mbits/sec
[1572]  0.0-85.9 sec  95.4 MBytes  9.31 Mbits/sec
[1560]  0.0-86.3 sec  95.4 MBytes  9.28 Mbits/sec
[1548]  0.0-86.5 sec  95.4 MBytes  9.25 Mbits/sec
[1512]  0.0-87.0 sec  95.4 MBytes  9.19 Mbits/sec
[1608]  0.0-87.2 sec  95.4 MBytes  9.17 Mbits/sec
[1536]  0.0-87.5 sec  95.4 MBytes  9.15 Mbits/sec
[SUM]  0.0-87.5 sec   954 MBytes  91.5 Mbits/sec
так с Juniper'ами я новичок, то буду очень благодарен если напишите по шагам для нубов.
спасибо
wingdog
Re: низкая скорость в Site-to-Site VPN между двумя SRX-240H
Сообщение Андрей » 24 май 2011, 19:17
Ошибки на портах есть?
Сообщение root » 25 май 2011, 09:16
wingdog писал(а):подскажите пожалуйста, что нужно подправить в следующем конфиге:
VPN туннелей на Juniper`ах ещё не поднимали, так что подсказать что подправить не подскажем.
wingdog писал(а):результаты iperf'а через этот туннель удручающие:
сами как то развлекались с тестами канала iperf`ом и их результаты не всегда были правдивы и запуск нескольких тестов подряд могли показать кардинально разные результаты.
посмотри что покажут UDP тесты, а так же поиграйся с ключем -P, увеличивая или уменьшая число параллельных потоков
т.к. странно, потому что железки Juniper VPN делают лучше чем аналоги у Cisco, как одно из подтверждений этого факта, что один крупный банк, в котором у меня друг работает (не будут называть его название), выбирает именно Juniper для построения туннелей, правда модель берут SRX650.
мы потом ещё пользовали:
Port: netperf-2.4.5
Path: /usr/ports/benchmarks/netperf
Info: Network performance benchmarking package
Maint: sumikawa@FreeBSD.org
WWW: http://www.netperf.org/
результаты были лучше чем показывал iperf
покажи вывод команды:
show interfaces
что там у нас с счетчиками
так же посмотри какая нагрузка на CPU девайса, в то время как ты выполняешь iperf тесты.
Сообщение wingdog » 26 май 2011, 20:54
сделал по рекомендации саппорта juniper
set security flow tcp-mss ipsec-vpn mss 1350
и проблема ушла.
спасибо!
wingdog
Сообщение root » 30 май 2011, 10:44
ясно, спасибо что отписал
wingdog писал(а):спасибо
да собственно нзчт :)
Сейчас этот форум просматривают: Google [Bot] и гости: 11
