Jun 10 10:33:28 goro named[373]: starting BIND 9.3.2 -u bind -t /var/named
Jun 10 10:33:28 goro named[373]: loading configuration from '/etc/namedb/named.conf'
Jun 10 10:33:28 goro named[373]: no IPv6 interfaces found
Jun 10 10:33:28 goro named[373]: listening on IPv4 interface de0, 192.168.1.1#53
Jun 10 10:33:28 goro named[373]: listening on IPv4 interface lo0, 127.0.0.1#53
Jun 10 10:33:28 goro named[373]: listening on IPv4 interface tun0, 217.24.*.*#53
Jun 10 10:33:29 goro named[373]: command channel listening on 127.0.0.1#953
Jun 10 10:33:30 goro named[528]: starting BIND 9.3.2 -u bind
Jun 10 10:33:30 goro named[528]: loading configuration from '/etc/namedb/named.conf'
Jun 10 10:33:30 goro named[528]: no IPv6 interfaces found
Jun 10 10:33:30 goro named[528]: listening on IPv4 interface de0, 192.168.1.1#53
Jun 10 10:33:30 goro named[528]: could not listen on UDP socket: address in use
Jun 10 10:33:30 goro named[528]: creating IPv4 interface de0 failed; interface ignored
Jun 10 10:33:30 goro named[528]: listening on IPv4 interface lo0, 127.0.0.1#53
Jun 10 10:33:30 goro named[528]: creating IPv4 interface lo0 failed; interface ignored
Jun 10 10:33:30 goro named[528]: listening on IPv4 interface gif0, 192.168.1.1#53
Jun 10 10:33:30 goro named[528]: creating IPv4 interface gif0 failed; interface ignored
Jun 10 10:33:30 goro named[528]: listening on IPv4 interface gif1, 192.168.1.1#53
Jun 10 10:33:30 goro named[528]: creating IPv4 interface gif1 failed; interface ignored
Jun 10 10:33:30 goro named[528]: listening on IPv4 interface gif2, 192.168.1.1#53
Jun 10 10:33:30 goro named[528]: creating IPv4 interface gif2 failed; interface ignored
Jun 10 10:33:30 goro named[528]: listening on IPv4 interface gif3, 192.168.1.1#53
Jun 10 10:33:30 goro named[528]: creating IPv4 interface gif3 failed; interface ignored
Jun 10 10:33:30 goro named[528]: listening on IPv4 interface tun0, 217.24.*.*#53
Jun 10 10:33:30 goro named[528]: creating IPv4 interface tun0 failed; interface ignored
Jun 10 10:33:30 goro named[528]: not listening on any interfaces
Jun 10 10:33:30 goro named[528]: could not get query source dispatcher (0.0.0.0#53)
Jun 10 10:33:30 goro named[528]: loading configuration: address in use
Jun 10 10:33:30 goro named[528]: exiting (due to fatal error)
killall -1 named
root писал(а):З.Ы. прикрути rndc
rndc-confgen
# Start of rndc.conf
key "rndc-key" {
algorithm hmac-md5;
secret "SjHGzamIIs2/8qhxOjQ2SQ==";
options {
default-key "rndc-key";
default-server 127.0.0.1;
default-port 953;
# End of rndc.conf
# Use with the following in named.conf, adjusting the allow list as needed:
# key "rndc-key" {
# algorithm hmac-md5;
# secret "SjHGzamIIs2/8qhxOjQ2SQ==";
# controls {
# inet 127.0.0.1 port 953
# allow { 127.0.0.1; } keys { "rndc-key"; };
# End of named.conf
и# Start of rndc.conf
помещаешь в файл /var/named/etc/namedb/rndc.conf (предварительно создав его)# End of rndc.conf
key "rndc-key" {
algorithm hmac-md5;
options {
default-port 953;
дописываешь в конец файла /var/named/etc/namedb/named.conf, убрав символ комментария (#)# Use with the following in named.conf
key "rndc-key" {
algorithm hmac-md5;
controls {
Start of rndc.conf
key "rndc-key" {
algorithm hmac-md5;
secret "to4bQ1MV6IUaVC5n******==";
options {
default-port 953;
# End of rndc.conf
key "rndc-key" {
algorithm hmac-md5;
secret "to4bQ1MV6IUaVC5n******";
controls {
End of named.conf
