Уведомления о пропущенных
Сообщение dimondack » 21 май 2021, 23:14
[local_context]
exten => _17XX,1,Set(fname=${STRFTIME(${EPOCH},,%Y%m%d%H%M%S)}-${CALLERID(number)}-${EXTEN})
exten => _17XX,n,MixMonitor(/var/spool/asterisk/monitor/${fname}.wav)
exten => _17XX,n,Set(recfile=/var/spool/asterisk/monitor/${fname}.wav)
exten => _17XX,n,Set(CDR(recfile)=/var/spool/asterisk/monitor/${fname}.wav)
exten => _17XX,n,Dial(SIP/${EXTEN},12)
;exten => _17XX,n,GotoIf($["${DIALSTATUS}" =="BUSY"]?vm)
exten => _17XX,n,GotoIf($["${DIALSTATUS}" !="ANSWER"]?vm)
exten => _17XX,n(vm),Macro(svm,${EXTEN},v_mail)
;exten => _17XX,n,HangUp()
exten => h,1,Noop(*****SEND to Telegram*************)
exten => h,2,Noop(***DIALSTATUS=${DIALSTATUS}*************)
exten => h,3,GotoIf($["${DIALSTATUS}" =="ANSWER"]?end)
exten => h,n,System(/usr/local/share/asterisk/agi-bin/scriptFINAL.sh  ${recfile})
exten => h,n,Hangup()
exten => h,n(end),Hangup()
[macro-svm]
exten => s,1,Wait(1)
exten => s,n,PlayBack(vm-nobodyavail)
exten => s,n,Wait(1)
exten => s,n,Voicemail(${ARG1}@${ARG2})
exten => s,n,Wait(2)
exten => s,n,HangUp()
sox, хорошо бы установить
sendOK_FINAL.php
#!/usr/local/bin/php -q
sleep(3);
define('TOKEN', '123123123123:Axgsfgsdfsdfsdfgsfdgsdf');  // bot TOKEN
define('CHAT_ID','-123123123123'); // group Telegram
define('TEMP_DIR_OGG','/home/tmp/'); //must be chown asterisk
//define('VOICEMAIL_CONTEXT','v_mail');
$i = explode('-',$argv[1]);
$cdn = $i[count($i)-2];
$j = explode('.',end($i));
$st = basename($i[0]);
echo basename($i[0])."\n";
//echo $argv[2]."\n";
$y=$st[0].$st[1].$st[2].$st[3];
$mon=$st[4].$st[5];
$d=$st[6].$st[7];
$h=$st[8].$st[9];
$min=$st[10].$st[11];
$sec=$st[12].$st[13];
$starttime=$y.'-'.$mon.'-'.$d.' '.$h.':'.$min.':'.$sec;
$ut=strtotime($starttime);
$pdir = '/var/spool/asterisk/voicemail/v_mail/'.$j[0].'/INBOX';
//$pdir = '/var/spool/asterisk/voicemail/'.VOICEMAIL_CONTEXT.'/'.$j[0].'/INBOX';
$last_mtimes= array();
//sleep(7);
if($dh = opendir($pdir)) {
$files = Array();
$inner_files = Array();
while($file = readdir($dh)) {
if($file == '.' ||  $file == '..'){continue;}
$pos = stripos($file,"wav");
if($pos===false){continue;}
 $lmtime = filemtime($pdir . "/" . $file) ;
$last_mtimes[$lmtime] = $pdir . "/" . $file;
$infile=end($last_mtimes);
$temp =pathinfo($infile);
$voicefile=$temp['filename'].'.ogg';
$last_txt =$temp['dirname'].'/'.$temp['filename'].'.txt';
//echo $last_txt;
//$str_origtime=0;
$fromfileutime=0;
$handle = fopen($last_txt, "r");
if ($handle) {
    while (($line = fgets($handle)) !== false) {
$pos = strpos($line,'origtime');
    if($pos!==false){
    $arrfile =explode('=',$line);
    $fromfileutime=trim($arrfile[1]);
                   break;   }
        // process the line read.
} else {
echo 'Error opening file '.$last_txt;    // error opening the file.
$s = 'Звонили c номера:  '.$cdn.' На номер: '.$j[0].'  Дата: '.$starttime.' ';
$response_txt = array(
   'chat_id' => CHAT_ID,
   'text' => $s,
   'method' => 'sendMessage'
//     echo "Not exist VoiceMessage";
sendTelegram('sendMessage',$response_txt);
exit(0);
fclose($handle);
if($ut > $fromfileutime)
   'text' => $s,
   else{
$cap = 'Звонили c номера:  '.$cdn.' На номер: '.$j[0].'  Дата: '.$starttime;
$sendf=TEMP_DIR_OGG.$voicefile;
//echo 'End file'."\n\r";
//echo $infile;
$cmd='sox -V '.end($last_mtimes).' '.$sendf;
//echo $cmd;
$output=shell_exec($cmd);
//$output=shell_exec('chown asterisk:asterisk '.TEMP_DIR_OGG);
//$f = $infile;
$f = $sendf;
//fwrite($fp,$f);
//fwrite($fp,'\n\r');
$cfile = new CURLFILE(realpath($f));
$resp_audio = array(
                'audio' => $cfile,
                'caption' => $cap
//sleep(3);
sendTelegram('sendAudio',$resp_audio );
//sendTelegram('sendMessage',$response_txt);
$method_img = 'sendPhoto';
$response_file = array(
             'chat_id' => $data['message']['chat']['id'],
             'document' => curl_file_create(__DIR__ . '/file.xls'),
             'method' => 'sendDocument'
sendTelegram($method_img,$response_img2);
sendTelegram($method_img,$response_img);
//echo 'TEST';
// Функция вызова методов API.
function sendTelegram($method, $response)
//    echo 'TEST';
        $ch = curl_init('https://api.telegram.org/bot' . TOKEN . '/' . $method);
        curl_setopt($ch, CURLOPT_POST, 1);
        curl_setopt($ch, CURLOPT_POSTFIELDS, $response);
        curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
        curl_setopt($ch, CURLOPT_HEADER, false);
        $res = curl_exec($ch);
        curl_close($ch);
        print_r($res);
        return $res;
// Прислали фото.
if (!empty($data['message']['photo'])) {
        $photo = array_pop($data['message']['photo']);
        $res = sendTelegram(
                'getFile',
                array(
                        'file_id' => $photo['file_id']
        $res = json_decode($res, true);
        if ($res['ok']) {
                $src = 'https://api.telegram.org/file/bot' . TOKEN . '/' . $res['result']['file_path'];
                $dest = __DIR__ . '/' . time() . '-' . basename($src);
                if (copy($src, $dest)) {
                        sendTelegram(
                                'sendMessage',
                                array(
                                        'text' => 'Фото сохранено'
        exit();
// Прислали файл.
if (!empty($data['message']['document'])) {
                'getFile',
                array(
                        'file_id' => $data['message']['document']['file_id']
        if ($res['ok']) {
                $dest = __DIR__ . '/' . time() . '-' . $data['message']['document']['file_name'];
                        sendTelegram(
                                'sendMessage',
                                array(
                                        'text' => 'Файл сохранён'
        exit();
// Ответ на текстовые сообщения.
if (!empty($data['message']['text'])) {
        $text = $data['message']['text'];
        if (mb_stripos($text, 'привет') !== false) {
                sendTelegram(
                        'sendMessage',
                        array(
                                'text' => 'Хай!'
                exit();
        // Отправка фото.
        if (mb_stripos($text, 'фото') !== false) {
                sendTelegram(
                        'sendPhoto',
                        array(
                                'photo' => curl_file_create(__DIR__ . '/45.jpg')
                exit();
        // Отправка файла.
        if (mb_stripos($text, 'файл') !== false) {
                sendTelegram(
                        'sendDocument',
                        array(
                                'document' => curl_file_create(__DIR__ . '/example.xls')
                exit();
scriptFINAL.sh
#!/bin/sh
 sleep 1
/usr/local/bin/php /usr/local/share/asterisk/agi-bin/sendOK_FINAL.php $1
#disown -h
 exit 0
Уведомления в Телеграмм, без голосового сообщения и с голосовым сообщением
