Cisco voice source-group и несколько операторов (VoIP->E1)
Re: Cisco voice source-group Trouble
Сообщение morom » 17 июн 2010, 08:45
sh call history voice brief показать уже не могу - таки перешел на маршрутизацию по префиксам.
Однако, вопрос остается открытым - хотелось бы докопаться до истины.
Ниже приведу кусочек вывода дебага
debug isdn q931
debug voip dialpeer all
debug voice translation
debug cch323 all
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215862: Jun 15 10:15:20.244 MSD: //-1/xxxxxxxxxxxx/H323/cc
h323_ct_main: SOCK 4 Event 0x1
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215863: Jun 15 10:15:20.244 MSD: //-1/xxxxxxxxxxxx/H323/cc
h323_gw_process_read_socket: owner_data=0x667E55C8, len=421, msgPtr=0x68DE41EC
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215864: Jun 15 10:15:20.244 MSD: //-1/xxxxxxxxxxxx/H323/cc
h323_gw_process_read_socket: Received msg for H.225
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215865: Jun 15 10:15:20.244 MSD: //-1/xxxxxxxxxxxx/H323/cc
h323_h225_receiver: Received msg of type SETUPIND_CHOSEN
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215866: Jun 15 10:15:20.244 MSD: //-1/xxxxxxxxxxxx/H323/se
tup_ind: Entry
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215867: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/setup_ind: callingNumber[number_A_op1] calledNumber[number_B_op1]
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215868: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/setup_ind: ---- calling IE present
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215869: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/setup_ind: ====== PI = 0
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215870: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/setup_ind: Receive: infoXCap 0
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215871: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/setup_ind: Receive: infoXCap ccb 0
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215872: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/setup_ind: Receive bearer cap infoXRate 16, rateMult 0
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215873: Jun 15 10:15:20.248 MSD: //-1/xxxxxxxxxxxx/H323/cc
h323_extract_signaled_carriers: Entry
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215874: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/cch323_determine_source_ip_group_info: No Source IP group match with Src CarrierId/Zone ID
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215875: Jun 15 10:15:20.248 MSD: //-1/xxxxxxxxxxxx/H323/cc
h323_determine_source_ip_group: Entry
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215876: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/cch323_determine_source_ip_group_info: Source IP group match with Access List
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215877: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/cch323_determine_source_ip_group_info: Call rejected with Disc. Cause = 63 by source ip grp
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215878: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/cch323_h225_receiver: SETUPIND_CHOSEN: src address = xx.xx.xx.2; dest address = yy.yy.yy.5
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215879: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/run_h225_sm: Received event H225_EV_REJECT while at state H225_IDLE
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215880: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/h323_set_release_src_and_iec: Failed AV set
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215881: Jun 15 10:15:20.248 MSD: //-1/xxxxxxxxxxxx/H323/h3
23_set_release_source_for_peer: ownCallId[116860], src[6]
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215882: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/cch323_h225_send_release: Cause = 63; Location = 0
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215883: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/cch323_h225_send_release: h225TerminateRequest: src address = 1311355394; dest address = yy.yy.yy.5
/var/log/cisco.log.1.bz2:Jun 15 10:15:20 cisco.local.lan 15215884: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/cch323_call_generic_cleanup: Disconnected flag 0
/var/log/cisco.log.1.bz2:Jun 15 10:15:21 cisco.local.lan 15215885: Jun 15 10:15:20.248 MSD: //-1/xxxxxxxxxxxx/H323/h3
23_gw_clean_send_blocked_watch: fd 4
/var/log/cisco.log.1.bz2:Jun 15 10:15:21 cisco.local.lan 15215886: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/run_h245_iwf_sm: received IWF_EV_H245_DISCONN while at state IWF_IDLE
/var/log/cisco.log.1.bz2:Jun 15 10:15:21 cisco.local.lan 15215887: Jun 15 10:15:20.248 MSD: //116860/2CBFE20C9CE0/H32
3/defaultHdlr: DEFAULT: Received IWF_EV_H245_DISCONN in state IWF_IDLE
/var/log/cisco.log.1.bz2:Jun 15 10:15:21 cisco.local.lan 15215888: Jun 15 10:15:20.248 MSD: //-1/xxxxxxxxxxxx/H323/cc
h323_cleanup_xport: hashDestroy for TcpFDTbl
/var/log/cisco.log.1.bz2:Jun 15 10:15:22 cisco.local.lan 15215889: Jun 15 10:15:22.800 MSD: //-1/xxxxxxxxxxxx/H323/cc
h323_ct_main: SOCK 0 Event 0x1
/var/log/cisco.log.1.bz2:Jun 15 10:15:22 cisco.local.lan 15215890: Jun 15 10:15:22.800 MSD: //-1/xxxxxxxxxxxx/H323/cc
h323_get_new_ccb: ccb (0x68BBEC04) is in use
/var/log/cisco.log.1.bz2:Jun 15 10:15:22 cisco.local.lan 15215891: Jun 15 10:15:22.808 MSD: //-1/xxxxxxxxxxxx/H323/cc
/var/log/cisco.log.1.bz2:Jun 15 10:15:22 cisco.local.lan 15215892: Jun 15 10:15:22.808 MSD: //-1/xxxxxxxxxxxx/H323/cc
h323_gw_process_read_socket: owner_data=0x667DDBB8, len=421, msgPtr=0x68546B50
/var/log/cisco.log.1.bz2:Jun 15 10:15:22 cisco.local.lan 15215893: Jun 15 10:15:22.808 MSD: //-1/xxxxxxxxxxxx/H323/cc
Это отбой вызова в случае настройки:
access-list + translation-rule + source-group
op2 был настроен первым - вызовы проходят успешно, по логам - ничего необычного, op1 - вторым - вызовы отбиваются с кодом 63
morom
Сообщение zaikini » 17 июн 2010, 10:11
У меня заработало в следующей конфигурации:
access-list 10 remark test_229
access-list 10 permit у.у.у.229
access-list 11 permit х.х.х.228
access-list 11 remark test_228
voice source-group test_228
 access-list 11
 translation-profile incoming test_228
voice source-group test_229
 access-list 10
 translation-profile incoming test_229
voice translation-rule 10
 rule 1 /^\.*/ /229/
voice translation-rule 11
 rule 1 /^\.*/ /228/
voice translation-profile test_228
 translate called 11
voice translation-profile test_229
 translate called 10
dial-peer voice 100 voip
 preference 1
 destination-pattern .T
 session protocol sipv2
 session target ipv4:у.у.у.229
 dtmf-relay rtp-nte
 codec g711alaw
 fax rate 9600
 fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
 no vad
dial-peer voice 101 voip
 preference 2
 session target ipv4:х.х.х.228
 dtmf-relay rtp-nte
 codec g711alaw
 fax rate 9600
dial-peer voice 10 pots
 destination-pattern 229.T
 direct-inward-dial
 port 0/2/0:15
dial-peer voice 11 pots
 destination-pattern 228.T
 direct-inward-dial
 port 0/2/0:15
zaikini
Сообщение morom » 17 июн 2010, 10:24
Пока, как я уже сказал, вопрос уже решил с помощью префиксов, но думаю еще вернусь.
Кстати, если не секрет, на чем делали?
PS Cisco IOS Software, 5350 Software (C5350-JS-M), Version 12.4(3), RELEASE SOFTWARE (fc2)
morom
Сообщение zaikini » 17 июн 2010, 10:35
5350 у меня под большой нагрузкой, эксперимент поэтому проводил на 2811 с IOS 12.4(13c)
zaikini
Re: Cisco voice source-group и несколько операторов (VoIP->E
Сообщение root » 17 июн 2010, 15:27
zaikini
большое спасибо за ответ
Сообщение zaikini » 17 июн 2010, 16:26
Это morom спасибо за вопрос))
zaikini
